dmaxx
Sep 21, 2023Aspirant
nighthawk app
running version 2.29.1.3147 of nighthawk app for android and my screens do not look like the ones on play store. any ideas why? I uninstalled my old version and reinstalled the current and no chang...
michaelkenward
Sep 22, 2023Guru - Experienced User
Which Netgear devices do you own?
Do you have any problems with using the app?
None of your screenshots shows the version of the app.
dmaxx
Sep 22, 2023Aspirant
I have a RAX43. I am running app version 2.29.1.3147, and the google play store states the same version. I uninstalled whatever version I was running and installed the current one from google play. currently I do not have any issues running the app.
- michaelkenwardSep 22, 2023Guru - Experienced User
That's good.
The look of the app depends on a lot of things, including how you have set it to look on your mobile device.
The app also relates to the firmware on your router, so it depends on whatever devices you are trying to control.
Some older devices needed updates to move on from the genie app to the Nighthawk app. The RAX range is young enough to be designed with the Nighthawk app in mind.
