Kehennig72
Feb 01, 2025Aspirant
Nighthawk app
My RAXE300 stopped working with Nighthawk app, I’ve tried powering cycling but nothing works. I can access the router via the internet browser but nothing works the app. Any suggestions?
Feb 02, 2025Guru - Experienced User
is anywhere access enabled in the app?
Are you using any vpn's or anything like that on the device running the app?
What actual error do you get?
- Kehennig72Feb 02, 2025AspirantYes anywhere access is enabled, no vpns.
The app worked before but I believe there was an update and since it won’t login. I don’t get any errors. I try to login after I enter my password it thinks for a minute then returns to login.- plemansFeb 02, 2025Guru - Experienced User
what modem/gateway is the router connected to?
- Kehennig72Feb 02, 2025AspirantUbiquiti Networks UF-Nano UFiber Gigabit Passive Optical Network Unit
