clrj14
Apr 25, 2020Aspirant
Nighthawk application (IOS) times out on login. (Model C7000)
Device: - iphone Xs max - ios version 13.3.1 Nighthawk application times out on log in. I've confirmed the password works by logging in on netgear genie just in case. I have also reset the passw...
clrj14
My apologies, I should have mentioned its a C7000v2 which is included on the support list. I'm assuming the nighthawk application is very similar to netgear genie and I have access to that so its not a big deal. Just wanted to bring it to the community's attention.
michaelkenward
Apr 25, 2020Guru - Experienced User
The Nighthawk App is supposed to support with the C7000v2. That is why it kind of helps to have the exact details.
Are you saying that the Netgear Genie app works? If so, this suggests that those links are wrong. Or it may depend on the firmware, but that is down to the ISP to deliver.
It is a case of one app or the other, but not both.
Some people think it was a step backwards when the genie died and they had to switch the NIghthawk app.
