larryis1
Jan 10, 2021Star
Nighthawk application stopped working on iPhone and iPad, HELP
I have been using the latest version of The nighthawk application on my iPhone and iPad, iOS 14.3. Recently the application no longer retains my password and when I can get the application to try to ...
larryis1
Jan 25, 2021Star
Tucson_Jim wrote:Same problem latest version of app on IOS is unable to communicate with the router. Fails to get device list, router specifics, even unable to reboot router. Router is functional however as we have been using for several days. Seems latest app is flawed. Even signing it,the app does not remember me.
It is sad that Netgear keeps on putting out applications that are defective and causing their users to have to install uninstall reinstall and continue to try where the application has zero chance of working. Netgear should test its applications thoroughly before releasing. I personally have wasted way too much time trying to use this poorly designed and ineffective application.
michaelkenward
Jan 26, 2021Guru - Experienced User
larryis1 wrote:
It is sad that Netgear keeps on putting out applications that are defective ....
In this case, Netgear did not put out a defective application. Apple made changes that broke the thing.
Netgear's crime is not having a clear enough crystal ball to know what Apple would do and not responding quickly enough. But that too may be down to Apple, which is famous for giving other brands a hard time.
- frenchcamp49erJan 26, 2021Star
I can confirm its not an iOS 14 problem. I also installed on an iPhone with 12.1.5 and get the same errors I get in iOS 14, I thinks its a Netgear firmware issue
- Tucson_JimJan 26, 2021Star
Interesting since we just had a firmware update. Wish the netgear folks would chime in and help us out here. I have invested a lot in netgear HW, modems & routers, would hate to lose faith now.
- Christian_RJan 29, 2021NETGEAR Employee Retired
Hello Nighthawk App users,
For us to to look into this further, may you provide the following info:
Router Model:
Router Firmware Version:
Nighthawk App Version: (please also specify if it's iOS or Android)
Local Network Access enabled: Yes/No (iOS only)
Rebooted Router: Yes/No
Thanks,
Christian
- larryis1Jan 26, 2021Star
I thought that was the case, as Nighthawk worked just fine before the last firmware update.
