larryis1
Jan 10, 2021Star
Nighthawk application stopped working on iPhone and iPad, HELP
I have been using the latest version of The nighthawk application on my iPhone and iPad, iOS 14.3. Recently the application no longer retains my password and when I can get the application to try to ...
M3DM
Jul 16, 2021Guide
Can Netgear fix or provide a solution to this issue. Prior to updating the iPhone app and the router firmware everything worked fine. Now the phone app is useless. Can anyone provide some customer assistance please?
larryis1
Jul 16, 2021Star
This problem has been continuous as Netgear issues updates to its Nighthawk App for iPhone & iPad without really testing the update completely... premature software update release. Prior to release everything works well with this Nighthawk App, then they do an update and the interface is LOST between the iOS app and the Router*. This is an unacceptable performance problem and Netgear should make it a priority to change its software development and release practices to not issue premature untested updates. Step up and serve your customers Netgear.
*Note: The Router works fine even though the iOS interface between the Nighthawk app & Router is considered non-functional.
Larry
