jimtonic
Jun 12, 2019Aspirant
nighthawk cannot remote manage router
nighthawk 2.3.6.617 R6400 version: 1.0.1.46 My R6400 is enabled "Remote Login" . Step: 1. Disable wifi from my cellular phone 2. Enable mobile network 3. Use Nighthawk app to look for ...
schumaku
Jun 12, 2019Guru - Experienced User
Don't be confused: The App based Remote Management is using a cloud system, it does - different from the Remote Login on the router settings - not open the management ports to the wild Internet.
Not all router models are allowing remote management using the Nighthawk App (earlier Genie App). However, I think your R6400 should alow to enable Remote Management while being connected to the local [W]LAN -> How do I enable or disable remote access on my router using the Nighthawk app?
jimtonic
the function degrates , true ?
Shall this function enable in the future ?
- schumakuJun 12, 2019Guru - Experienced User
jimtonic wrote:the function degrates , true ?
Same Nightawk App functionality either way. No big impact on the performance.
jimtonic wrote:Shall this function enable in the future ?
Not sure what you want to ask here - yes, you can enable/disable this feature later.
- jimtonicJun 12, 2019AspirantBrowse
NETGEAR ® COMMUNITY
United States
Re: nighthawk cannot remote manage router
jimtonic
jimtonic
4
Reply To Message
Model (Recommended - Helps the community give the best answers)
Email me when someone replies
View discussion in a popup
REPLYING TO:
schumaku
schumaku Sensei Sensei
2019-06-12 10:00 PM
My business requirement is 1. To control my router outside my home, outside my wifi range.
It does really make me uncomfortable, inconvenient l.
Haha, lets go and see.
Put it in this way. The new app should be better the former or existing one, not to degrates.
