jimtonic
Jun 12, 2019Aspirant
nighthawk cannot remote manage router
nighthawk 2.3.6.617 R6400 version: 1.0.1.46 My R6400 is enabled "Remote Login" . Step: 1. Disable wifi from my cellular phone 2. Enable mobile network 3. Use Nighthawk app to look for ...
jimtonic
the function degrates , true ?
Shall this function enable in the future ?
schumaku
Jun 12, 2019Guru - Experienced User
jimtonic wrote:the function degrates , true ?
Same Nightawk App functionality either way. No big impact on the performance.
jimtonic wrote:Shall this function enable in the future ?
Not sure what you want to ask here - yes, you can enable/disable this feature later.
- jimtonicJun 12, 2019AspirantBrowse
NETGEAR ® COMMUNITY
United States
Re: nighthawk cannot remote manage router
jimtonic
jimtonic
4
Reply To Message
Model (Recommended - Helps the community give the best answers)
Email me when someone replies
View discussion in a popup
REPLYING TO:
schumaku
schumaku Sensei Sensei
2019-06-12 10:00 PM
My business requirement is 1. To control my router outside my home, outside my wifi range.
It does really make me uncomfortable, inconvenient l.
Haha, lets go and see.
Put it in this way. The new app should be better the former or existing one, not to degrates.
