jimtonic
Jun 12, 2019Aspirant
Nighthawk cannot show wired connected device
 R6400 firmware: 1.0.1.46  Nighthawk version  2.3.6.617        In my fomer app , Nergear Genie allows me to reach the wired + connected device, such as my television. I can disable the connectivity be...
- Jun 12, 2019The Nighthawk App and the compatibility with all routers seems to be a big can of worms, issues wherever we are looking for. That's a new one, and I like to add it to the Nighthawk App Bug thread -> https://community.netgear.com/t5/Nighthawk-App/BUG-REPORT-Speed-Test-Information-Home-Screen-Wrong-Speed-Test/m-p/1737540#M9371 For now there is no other way but using either the desktop Genie (Windows or MacOS), or the router Genie Web reachable on the local [W]LAN on http://routerlogin.net/
schumaku
Jun 12, 2019Guru - Experienced User
- jimtonicJun 12, 2019AspirantThe Nightwhawl is a mess. Cam metgear switch back "Netgear Genie" ?4 What is the main cause that Genie is disabled ? - schumakuJun 12, 2019Guru - Experienced UserWould love to hear an answer from Netgear, too.
 Let's guess: Marketing, standardisation (sigh....), getting rid of dated code, getting rid of features like file transfer, UPnP AV/DLNA server (on Windows/MacOS), ...
