manfred1953
Apr 20, 2023Aspirant
Nighthawk cax80 and nighthawk app
I was having a big problem with not being able to login with the router’s credentials VIA THE NIGHTHAWK APP. I checked to make sure that my login and pw were correct in the router - they were( I could...
michaelkenward
Apr 21, 2023Guru - Experienced User
Which one? iOS or Android? From the text I assume iOS.
Have you seen this?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
manfred1953
Apr 21, 2023Aspirant
I believe I stated it was an Apple phone which makes it ios ..
