manfred1953
Apr 20, 2023Aspirant
Nighthawk cax80 and nighthawk app
I was having a big problem with not being able to login with the router’s credentials VIA THE NIGHTHAWK APP. I checked to make sure that my login and pw were correct in the router - they were( I could...
manfred1953
Apr 21, 2023Aspirant
Since one of the vpn’s was NETGEAR’s VPN you would think netgear would KNOW this but having looked at all the solutions from netgear concerning this ..NOPE not a peep .and I’ve seen several users experiencing the same problems I was having , it was worth putting out there to inform everyone… .
Apr 21, 2023Guru - Experienced User
Something you could file a bug report on:
