Hope8
Apr 27, 2019Aspirant
Nighthawk Install App: does not detect router
(Model is v3) I upgraded my router from Linksys E1000 to the Nighthawk AC1750/R6700v3 using the Netgear Nighthawk App. Install and connection to the WiFi network name & password provided was successf...
michaelkenward
May 01, 2019Guru - Experienced User
Hope8 wrote:
(Model is v3)
A better way to describe that might be replaced my router from Linksys E1000 to the Nighthawk AC1750/R6700v3.
You can't just unplug one router from your network and replace it with a different router. You have to rebuild the network.
As this is a router, there is probably a modem sitting in front of it. You need to get the router to forget its misspent past with the old modem. That means rebooting the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
When you do restart the computers, remember that you have changed the network. Your PCs are joining a new network. So you may have to make some changes to the network settings. Windows, for example, may assume that you are now on a "public" network and block access to the Internet. So you may have to change that setting.
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
