chrisspurgeon's avatar
Jun 16, 2019
Nighthawk IOS app can't perform R7800 firmware update
I have a Nighthawk R7800 and have no problems accessing it via the IOS Nighthawk app. I can do things like load the Device Manager to see the devices currently connected to my network, and see my current WiFi settings. But the firmware update functionality never works. I bring up the Router Settings in the app, and click the "Check For Updates" button. The app then loads a screen saying it's Checking for New Firmware, but after about 20 sec or so a "Firmware Check Error" page appears in the app, with the message "There was a problem checking firmware update".
Any idea what's going on? I believe I have the current version of both the Nighthawk app and the IOS operating system.
  • michaelkenward's avatar
    michaelkenward
    Not really, just a word of warning, where possible avoid firmware upgrades over wifi.
    They even warn against this in the release notes:
    R7800 Firmware Version 1.0.2.62 | Answer | NETGEAR Support
    Note: To avoid wireless disconnect issues during the firmware download process, NETGEAR recommends that the firmware upgrade be performed on a computer with a wired connection.
    If you don't have wired access, then you could try the browser on your mobile device.
    By the way the "Check For Updates" button isn't always reliable either. It can miss updates that are available on the support pages for the device.
    There is support for the R7800, including a manual and firmware, somewhere at the end of this link:
    >>> R7800 | Product | Support | NETGEAR <<<
    • chrisspurgeon's avatar
      chrisspurgeon
      Huh, interesting. Thanks!
      I guess the obvious question now is...if Netgear says firmware updates via WiFi and the app are unreliable, WTF do they offer that feature?
        michaelkenward
        Some people like to live dangerously.
        It works most of the time. It is probably there because the lawyers demanded it.
