Addiosamigo2020
Dec 18, 2020Follower
Nighthawk iOS app doesn’t respond when renaming devices
I purchased a second hand one of these and it arrived yesterday, setup was quite easy.
I started renaming my devices and choosing icons for them, and this was going quite well.
I noticed that my surface couldn’t connect to the 5ghz and I fixed that by changing the channel.
When I went to rename devices in the nighthawk app it would no longer do this, just whirly wheel of wait and then when I restarted the app it wouldn’t connect and I’d have to reboot the router to get it to work again.
If I go in to access control of the router I can sometimes change the devices in there, but not always.
Does anyone have the same issue? Any fixes?
Firmware : v1.0.4.102 (North America, even though I live in Europe...)
1 Reply
- Christian_RNETGEAR Employee Retired
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
