rlwoolsey345
Jan 02, 2021Follower
Nighthawk Login Timed Out
I have a Netgear model R7900P router Firmware V1.4.1.66_1.3.26 and have Nighthawk V2.7.2.1373 on my phone. I was notified of a firmware update. When I tried to connect with Nighthawk, after verifyi...
michaelkenward
Jan 03, 2021Guru - Experienced User
Is that Android? iOS has been having a hard time following one of Apple's troublesome uodates.
Login to the device can be a two-stage process. First the wifi, then the interface. It is even more complicated if you use Anywhere Access.
rlwoolsey345 wrote:
I can connect with routerlogin.net with no problem.
There are several ways to connect with routerlogin.net. If this mean that you can connect with a wired LAN link and the browser graphical user interface (GUI) that is the best way to get in and update firmware. It doesn't rely in a wifi connection that might die mid-update, wrecking your router in the process.
The preferred option for experienced users is this one:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Check the section in the manual on updating the firmware.
