Myronjax1953
Dec 12, 2022Aspirant
Nighthawk Mobile App device manager
Hello. I have a Nighthawk R7000 router. While using the mobile app, i have discovered that, under the Device Manager, all of my connected devices have an "allow access" button except one. It's descri...
- Dec 13, 2022
Michael,
did some sleuthing and....the answer was right under my nose...kinda. Turns out that the iphone-my iphone-the iphone in my hand that has the Nighthawk app telling me there is an unknown device i cant block hooked up to my local WiFi network-that iphone is the "unknown" device that i'm looking forđ€Ł Apparently, the latest IOS's have a "Private WiFi" address, and the default setting is "on"...wait-just figured it out. The app wont give my access to block wifi access to "myself"- would be kinda dumb. That's why there is no "block access" button. Problem solved. Thanks for pointing me in the right direction (MAC address). Appreciate the help!
Jim
Myronjax1953
Dec 13, 2022Aspirant
Michael,
Thanks for the suggestion! In the App's device manager, each device does give you it's IP address, as well as it's MAC address. I'll do some sleuthing with the various WiFi connected devices in my house and see if i can find and identify each. Thanks!
Jim
michaelkenward
Dec 13, 2022Guru - Experienced User
IoT toys have a habit of staying under the radar.
