Not2Techy
Jun 05, 2022Aspirant
Nighthawk MR60
Night hawk app says ‘router not found’ on iPhone. It also shows that iPhone is ‘offline’. I have unplugged router and replugged, reinstalled, deleted app and reinstalled several times, called suppor...
michaelkenward
Jun 07, 2022Guru - Experienced User
The app works fine on my iPad
If it works on one device but not on another, the first place to investigate is the device that doesn't work.
Have you tried to troubleshoot there?
First "forget" and recreate the wifi link from the iPhone to the router's wifi.
You have already tried the other obvious option, uninstall and reinstall the app.
- Not2TechyJun 07, 2022AspirantThank You! I had previously done all of that and nothing changed.
As I said above, it happened once I installed Bitfender, so in total frustration this morning, I deleted the bitdefender app and lo and behold, my problem was rectified.
