tland54's avatar
tland54
Nighthawk Not Detected on App
I recently had to factory reset my router because I forgot my security questions to access the router login. Accessing the router login was requried for me to do to gain access to ExpressVPN router coverage. After doing the steps that ExpressVPN had provided, everything seems to be connected. Except the App on my iPhone. Wifi is working on my computer, Xbox, and Phone, but for some reason it won't find it on the Nighthawk app. I tried disabling the VPN on all apps, disabled the VPN via IP address lookup, and still the app is not finding the router. I've done everything I could, from factory reseting it again, to Try a New System Setup process. It mentioned on the app that the VPN could be the reason why I can't connect the app to the router. But as stated eariler, I already disabled every VPN app and still nothing.
Any ideas on how to fix this?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello tland54,
    Have you had a moment to reinstall the Nighthawk app? May you provide us with the current Nighthawk app version number installed on your mobile device.
    Christian
    • tland54's avatar
      tland54
      I have already uninstalled and reinstalled the app multiple times. My Local Network is on by default.
      App Version: 2.7.2.19
