Batman-15
Dec 21, 2019Tutor
Nighthawk R6900P iOS app uses what protocol to connect to the router
Good Morning: Here is my question: What protocol does the Netgear iOS iphone app use to connect to the router? IE: HTTPS, TCP, UDP, etc? Thanks - Batman
michaelkenward
Dec 29, 2019Guru - Experienced User
I fear that the lack of answers suggests that no one understands the question. I certainly don't.
Maybe if you said why are you asking someone might be able to help.
- Batman-15Dec 29, 2019TutorThe answer is self-explanatory. On the iPhone when you tap on the nighthawk app what protocol does it use to communicate with the router. HTTPS, UDP, TCP/IP.I am looking to find out if the communication is secure or not secure. Another way to put it is it an encrypted.
Thanks in advance!- schumakuDec 31, 2019Guru - Experienced User
Not very difficult to figure out - plain text HTTP SOAP - .2 is the mobile, .254 is a Netgear R9000:
This applies even to Nighthawk routers supporting https - while the https://routerlogin.net/ is encryted and the certificate is trusted all firmware at least of a similar generation) does come with the very same certificate - and private key.
Now, for most deployments - leaving e.g. Orbi with a wired backhaul out of scope - the mobile device App does connect direct over the already encryped WPA2 link (or WPA3) unless the admin has configured something silly with the router. So what's the fuzz here - it's just consumer junk anyway?On a broader IT security view, it's more essential how the encryption is done, how the keys are exchaned, how the keys are generated, ...
PS: For somebody keen to know it won't be difficult to figure out discoving the same insight - not much criminal energy required.- Batman-15Jan 02, 2020TutorThank you for your response! It is exactly what I needed.
