Dean_
Jul 17, 2017Tutor
Nighthawk r7000 and netgear genie.
Hello all, I have registered my device with netgear,and I can see it on my account. But when I try remote access with genie, It says select router,but my router is not there? Also when I login...
Dean_
Jul 17, 2017Tutor
It was working fine last week, I reset the router and up graded to Firmware Version V1.0.9.6_1.2.19.
I can log in by remote management, but I'd prefere to see my router and use genie.
- Dean_Jul 20, 2017TutorHello all,
Had another go at genie this morning, went to remote access and now it is turned on by itself.
So then went to login by remote, it says select router, my router was there now. So continued, and worksđ.
The only downside I noticed, is I have renamed by devices, when I log in remote, it keeps the names of the original device.
So I might have to change that.
So try yours today and see what happens.
My genie app is iOS 3.1.28
