grandpa6times
Jul 04, 2022Aspirant
Nighthawk r7800, 2600 Phonr App cannot find the router
I have a Nighthawk R7800 A.C. 2600. I have hooked it up and everything seems to work correctly. But everything I have tried in order to get the Android App to work has failed. No matter what I do I...
Jul 04, 2022Guru - Experienced User
what modem/gateway is it connected to?
are you able to access it using its IP address?
- grandpa6timesJul 04, 2022Aspirant
THe modem is Comcast Xfinity. I dont know what you mean by gateway. What exactly do you mean by gateway.
Thank you in advance for any help you can give me.
- grandpa6timesJul 04, 2022AspirantSorry for double post but here is the modems information.
- plemansJul 04, 2022Guru - Experienced User
That "modem" is a modem/router combo device. It causes a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
