jmwatt1234
Jun 16, 2023Aspirant
Nighthawk RAX120 - unable to login to router from Edge browser
Recently install Nighthawk RAX120 router. I have been attempting to login from Edge browser. I did have a successful login from the web browser - but now get "authorization issue" at login - cha...
- Jun 22, 2023
apologies - i meant to type in "netgear modem"
I have resolved my login issue
I did an admin password change from a web browser - turns out, the web browser login did NOT display pw error - i had entered an alpha only pw - maybe there was a pop up with the error? i usually block pop ups from the browser-so the error could have been a pop up message box
From my iPhone app the login update displays the rules for valid login-so from the web i entered pw according to the rules from iPhone app- and login from web was successful
so could have been a "popup blocker" on situation....
Thanks again for responding
Jun 16, 2023Guru - Experienced User
Did you try a different browser?
Also, when you changed the password, did it meet minimum requirements?
Tried a simple factory reset/reinstall?
jmwatt1234
Jun 19, 2023Aspirant
Tried Firefox and Brave
New pw was valid
thanks for responding
- plemansJun 21, 2023Guru - Experienced User
what modem/gateway is it connected to?
Might try a simple factory reset/reinstall
- jmwatt1234Jun 21, 2023Aspirant
I use a Netgear router
Will give router reset a try
Thanks for y our response
I get you have the RAX120. but what modem/gateway is it connected to?
