PLUChris's avatar
PLUChris
Nighthawk RAX50 no longer allows me to connect
Router has been running fine for a couple of years, but today I can no longer connect either on a pc or a mobile device
  • michaelkenward's avatar
    michaelkenward
    Jan 24, 2022
    PLUChris wrote:
    what modem/gateway are you on? XFinity----This would be an ISP. not your gateway. What gateway do you have from xfinity?  CGM4331COM
    That looks like a gateway, a modem/router. So you have two routers on your network.
    Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
    It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. There may be ways to get the modem/router to cooperate.
    XFI Gateway (Technicolor CGM4331COM) in bridge mode question : Comcast_Xfinity
    Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
    Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
