themrsbake
May 07, 2023Aspirant
Nighthawk rax50 showing extra iPhone.
We have two iPhone 13’s. An extra iPhone is showing connected on my Devices. It looks connected and even has more information. For example, which line (2.4ghz) it’s connected to. Why is this? The othe...
May 07, 2023Guru - Experienced User
Are you using apples random mac/ip address feature? Or icloud relay?
- themrsbakeMay 07, 2023AspirantHi, I’m using Apple’s random Mac/ip address feature.
- michaelkenwardMay 08, 2023Guru - Experienced User
themrsbake wrote:
Hi, I’m using Apple’s random Mac/ip address feature.NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
- plemansMay 08, 2023Guru - Experienced User
themrsbake wrote:
Hi, I’m using Apple’s random Mac/ip address feature.Try disabling them. They can cause issues for services that use the ip address/mac address.
