jkcanvas
Mar 10, 2022Guide
Nighthawk Router Not Found
So I have been trying to log into my router using the Nighthawk app, which seems to not find it. So I have followed all the proceedures and still no joy. I went and looked for the router IP address...
Mar 10, 2022Guru - Experienced User
1. what router do you have?
2. what modem is it connected to? Xfinity modem isn't quite thorough. And if its a modem router combo device as you imply, its causing a double nat. A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
---- Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
-----Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
------Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
3. what firmware is on the router?
4. if you're currently running in double nat mode, the netgear usually switches its default ip address to 10.0.0.1. Have you checked that address?
