CalebReynaud
Feb 10, 2024Follower
Nighthawk router
Trying to set up nighthawk router on app but keeps saying configuration error
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageOr set using a PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
What router model are you setting up? - michaelkenwardGuru - Experienced User
CalebReynaud wrote:
Trying to set up nighthawk router on app but keeps saying configuration errorNot much to go on there.
What router is that?
At what stage do you get that error?
But as FURRYe38 says, manual installation is more reliable and gives you more control.
