Bosco78
Mar 10, 2025Aspirant
Nighthawk RS-700
How do you use the Nighthawk App to change or access Access Control? I recently used a web browser to log into the router but the access control section was blank. It says you can use the Nighthawk A...
Mar 10, 2025Guru - Experienced User
Should be able to select a device under Devices and there is a pause button that you can select to stop access if needed.
