Bosco78
Mar 10, 2025Aspirant
Nighthawk RS-700
How do you use the Nighthawk App to change or access Access Control? I recently used a web browser to log into the router but the access control section was blank. It says you can use the Nighthawk A...
Bosco78
Mar 11, 2025Aspirant
What app do you need?
Mar 11, 2025Guru - Experienced User
Access Controls should be seen in the WEB UI, only if you enabled Smart Parental Controls or subscribe to that feature, then Access Controls doesn't appear on the routers WEB UI.
- Bosco78Mar 19, 2025Aspirant
I never had parental controls enabled.
- michaelkenwardMar 19, 2025Guru - Experienced User
Did you find this?
Get there from the Home tab:
If you follow the link I circled you should get here:
There are various options in there.
