Bosco78
Mar 10, 2025Aspirant
Nighthawk RS-700
How do you use the Nighthawk App to change or access Access Control? I recently used a web browser to log into the router but the access control section was blank. It says you can use the Nighthawk A...
michaelkenward
Mar 10, 2025Guru - Experienced User
That feature is now App Only. It isn't there with a web browser and the graphical user interface (GUI).
Disclaimer: Just another user with time on their hands.
Bosco78
Jun 24, 2026Aspirant
Mine is also blank. It says to use Nighthawk app. I find it hard to use and does not effectively block intruders . You have to manually block them.
