Deadpidge
Feb 22, 2025Aspirant
Nighthawk RS200 - White screen via andriod nighthawk app
Nighthawk app very briefly shows main home screen, but then turns too a solid white screen with a blue header. Unable to screenshot due to in app security policy. Report bug works, but no confirmati...
Feb 24, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Is this for Android? Be sure that the Android OS is not blocking screen captures or screen shots for applications. Orbi app doesn't prevent screenshots or captures. Only the mobile OS can do that.
- DeadpidgeFeb 24, 2025Aspirant
This is Nighthawk for Android running on an S23ultraPhoto rather than screenshot
