porinha2
Dec 17, 2024Aspirant
Nighthawk update help!
I couldnt get the router to update the firmware using the app so i called support and was told i have to pay for a subscription of 120 dollars just so i can get help with update. Do i have to pay or is there a way to update without? Should i just buy a new router?
1 Reply
Try manually updating the router using a wired PC and web browser?
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
