snoozbuttons
Jun 26, 2020Follower
Nighthawk updated now has Armor, but can't use VPN really sucks!
How do I bypass using Armor and VPN or can I? I have to turn off Armor to use VPN. Looks like Armor is useless & would be a waste of money.
1 Reply
Sort By
What VPN are you attempting to use (connect) on which platform (MacOS, Windows, Android, iOS) and where do you have to disable Armor - on the router, on the device from where you attempt to establish the VPN connection?
Unless I'm wrong, there is no Armor VPN module on the router itself so you seem to talk of What is Bitdefender Security which has to be shut-down on the computer or mobile ... either because of the platform does not allow having multiple VPN configured, or because of the Bitdefender Security does prohibit using whatever VPNs.
