ush6971
Mar 17, 2021Follower
Nighthawk X10 AD7200 Smart WiFi Router Parental Controls
There is no parental controls on the nighthawk app. Whn i log into the router on my PC it says parental controls is NOT ENABLED. When i click parental controls it takes me to a netgear ad for netgear...
michaelkenward
Mar 20, 2021Guru - Experienced User
Netgear has removed support for free parental controls from the Nighthawk App for mobile devices. It is also making it harder to enable parental controls in other ways.
If you haven't been there already, the first thing to try is the browser graphical user interface (GUI). This is the way into the router's controls with a wired connection from a PC.
An alternative is to begin with the desktop genie for your operating system.
Here too Netgear wants to kill off this useful tool and is hiding the usual landing pages for the software. If may still be on the support section for your hardware, feed in your model number here:
Support | NETGEAR
If not, it might still be here:
genie Landing Page | Apps | Discover | Home | NETGEAR
Scroll to the bottom and find the version for your operating system.
When it comes to managing Parent Controls after it is running, this is probably the best way in:
https://netgear.opendns.com/sign_in.php
Good luck, you may need it.
Netgear has just announced that it is killing the free Live Parental Controls. So don't get to rely on it.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
zolo
May 16, 2022Tutor
I usually look at user guide documentation before buying something like a router. I did this with Netgear x10 ad2700 and there is a large section of the user guide dedicated to parental controls. Neatgear clearly does not care if their documentation is up-to-date. The main thing they want is for you to have to buy a new router that requires a subscription to parental controls. LOL
https://www.downloads.netgear.com/files/GDC/R9000/R9000_UM_EN.pdf
- michaelkenwardMay 17, 2022Guru - Experienced User
The R9000 – the correct Model Number for what you mistakenly call the x10 ad2700 which is a wifi technology indicator that is also used by other brands – dates back to 2017. A lot has changed since then, not all of it under Netgear's control.
There have been around 25 firmware updates for this device. Many of these, like the latest, are Security Fixes. But they also add, remove and change features. These features are also tied to the various apps that are there to help users to manage their devices.
Netgear has modified Parental Controls, partly because they used to depend on a third party intermediary.
As that explains, it is still possible to use the old approach and to get some free protection.
- zoloMay 17, 2022Tutor
security controls are not the same as parental controls
OpenDNS + R9000 = zero parental controls
- FURRYe38May 17, 2022Guru - Experienced User
Was told that the R9000 only had support for OPENDNS on the router however that service thru NG was discontinued last Dec 2021.
However, I was also told that you could go to the OpenDNS site and setup an account there, then input OpenDNS dns addresses into the routers Internet/Use these DNS addresses here and the router will filter all items thru OpenDNS's services that way.
