Libertas12
May 16, 2020Aspirant
Nighthawk X4S AC3200 - Use an app on my phone to set up?
I have yet to connect this to my Xfinity system, using their Gateway now. A friend bought a new Netgear 3.1 Modem from Amazon and when Comcast proceeded to activate it they told him it was already i...
Libertas12
May 17, 2020Aspirant
Thank you for responding, no I have not tried to do it yet...I wont have a wifi signal until AFTER
Xfinity activates it and I hope that part goes smoothly. I havent done anything yet, afraid it will go sideways and so on plus it is in a high place in the laundry room , hard to reach, waiting for shelter in place to be over to get relative to help.
I am going to see if I take it to the office can they do it there as I have no cellular etc.
michaelkenward
May 17, 2020Guru - Experienced User
This may not be the case. You will have wifi, but no Internet.
The idea of the app is that it connects your wifi client, the phone, to the wifi from the C7800 and then takes you through the setup process.
You do not need "cellular" to set it up. You use the wifi from the C7800. Connect to that from the phone. No need to connect to the cell network.
But if you read the Quick Start guide (see link above), or the full manual, you will see that it recommends using a wired connection to the modem/router to set it up.
The Quick Start guide also has a section Activate Your Internet Service. Did you read that?
