Wisguy
Apr 16, 2020Aspirant
Nighthawk
Setting device to no Wi-Fi access does not stay set. When I select that setting for a device and check it the next day the status changed to allow access.
michaelkenward
Apr 17, 2020Guru - Experienced User
What Netgear device are we talking about here? There are dozens of "Nighthawks".
What do you mean by "no Wi-Fi access"? You turned off the wifi? Blocking a device? Something else?
Start by explaining what you want to achieve and someone might come up with an idea.
Wisguy
Apr 17, 2020Aspirant
App 2.4.24.1
Firmware 1.0.9.88
In the app I want to temporarily block Wi-Fi access using the nighthawk app. I set the device to no access and check the app the next day and the status reversed itself thus allowing Wi-Fi access.
Firmware 1.0.9.88
- michaelkenwardApr 17, 2020Guru - Experienced User
Wisguy wrote:
Firmware 1.0.9.88Not quite the latest.
Wisguy wrote:
In the app I want to temporarily block Wi-Fi access using the nighthawk app.Block access to what? An attached device of some sort?
- WisguyApr 17, 2020AspirantYes. An Android tablet.
