thedarc69
Nov 11, 2023Follower
Nighthawk
I need admin password trying to put in app & nothing works
1 Reply
Sort By
thedarc69 wrote:
I need admin password trying to put in app & nothing worksPassword for what?
A Nighthawk router?
Unless you have changed it the default admin password (which is written on the label of the thing) is password.
If you changed it and can't remember what to, and did not enable password recovery, you will have to reset the thing and start from scratch.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
