VP2k
Aug 01, 2019Follower
Nighthwk Android App
Nighthawk App version V2.4.1.721 for Android. I am having problems turning ON/OFF devices from LG G7 and Samsung Galaxy S7. when trying to turn a device OFF, "Please try again later" appears on ...
michaelkenward
Aug 03, 2019Guru - Experienced User
How are you connecting the Nighthawk app to the the RAX120? Local wifi?
If you enable Remote Access and sneak in that way it might work.
You may be able to use Remote Access and Remote Management even if you are on your own network.
