Wins10P
Jun 30, 2020Tutor
No Device Names
I am running firmware version: 1.0.2.130 App version 2.5.4.0 I had to update my router because it just wouldn’t work. It stopped sending data, I reset it and updated the firmware. My previous vers...
Christian_R
Jul 07, 2020NETGEAR Employee Retired
Hi Wins10P,
Have you had a chance to reinstall the Nighthawk app or try another mobile device?
Christian
- Wins10PJul 11, 2020TutorI did, seems to be an update issue. I ended up buying a Mesh, then the RAX75 after finding the mesh flopped big time. They both immediately pre-filled the devices.
