syko12345's avatar
syko12345
No internet connection on setup R7000
Hi all,   i recently got my hands on a Netgear Nighthawk R7000 router. I currently from the UK and my ISP is BT (BT infinity 1 FTTC) and i currently use their Home Hub 5 (which has a built in modem...
  • syko12345's avatar
    syko12345
    Oct 08, 2015
    Hi Mate,
    Thanks for your swift response.
    I have managed to get everything working. All i had to do was setup the router manually and enter the ISP login details ([email protected] pass: BT)
    thanks!
