notagain's avatar
notagain
no way to download firmware upgrade dgn2200v4
the genie page says there's an upgrade and do I want to download it.  But it gives no way to do so.  There isn't a yes / no / check box or whatever.  Please would someone advise how to download this?  Searched netgear drop-down boxes but they didn't even list this router.  help appreciated.  Thank you :)
  • I'm not sure what current firmware version your running on, however the newest firmware version on the NETGEAR Support site is v1.0.0.66 (All Regions Except Germany). I have also check the DGN2200v4 firmware folder and nothing has newer has been released to the public.
    So if you are looking to update to v1.0.0.66, and unsure how to, I suggest reading the NETGEAR Support article: Installing Latest Firmware on a NETGEAR router
    If you would like to install the firmware manually read this guide.
    If you need anything else, feel free to ask.
    • notagain's avatar
      notagain
      Hi.  You've got the right upgrade, but I'd already tried all your solutions before posting on this forum.  I can't download it manually because, although the update is availale, the netgear site doesn't recognise anything relevant to this router model.  Still hoping for a solution!
      • netwrks's avatar
        netwrks
        Master
        Just download the firmware to your laptop / desktop from the NG web site. Use the browse function to upload to your router..
         Router manual link - See Page 73.
