AzAyA
Mar 09, 2020Initiate
Not supported in Nighthawk app
I just purchased this brand new modem router and not able to get it set up in the new nighthawk app. It’s states that it’s not supported. This is a brand new top of the line modem router that was exp...
michaelkenward
Mar 10, 2020Guru - Experienced User
This is a brand new top of the line modem router that was expensive and I can’t set it up in this new app, please help?
I don't know where you read that the Nighthawk app supports this device. It isn't on this list:
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation.
You can get the Quick Start guide there.
You may find that the Netgear Genie appworks with this device.
This predates the Nighthawk app.
- AzAyAMar 10, 2020InitiateI just typed Nighthawk and this app came up so I downloaded it and tried setting it up. If my device is called Netgear Nighthawk then I would, like many others, assume that the Netgear Nighthawk app would work. Just saying. I have the Netgear Genie app and it’s working great so far.
- michaelkenwardMar 10, 2020Guru - Experienced User
AzAyA wrote:
If my device is called Netgear Nighthawk then I would, like many others, assume that the Netgear Nighthawk app would work.You and I may think that, but Netgear needs to update the firmware on your modem/router for that to work. Sadly, your Internet service provider controls the firmware on your modem/router and most seems to be reluctant to update firmware on third party hardware.
AzAyA wrote:
I just typed Nighthawk and this app came up so I downloaded it and tried setting it up.Wasn't there a bit of paper in the box that told you what to do?
