Automator59
Jan 24, 2021Tutor
Nuisance Security Alerts, goforandroid.com
I just installed the RAX70 router and added the security in the app. I keep getting a spam alert for goforandroid.com and cannot figure out what that is for. It occasionally shows for my Samsung Ga...
Automator59
Jan 25, 2021Tutor
The alert comes in through the Nighthawk app, security tab, and pops a notification on my phone. The app was installed to setup the RAX70 router. What is meant by linkspam?
Christian_R
Jan 25, 2021NETGEAR Employee Retired
Hello Automator59,
This is a false positive detection and should be resolved by now. You should be able to access the website without any issues. For future reference, if you run into a similar issue you may report it Bitdefender using the link below.
https://bitdefender.com/submit
Christian
