miguelr0man
May 23, 2022Aspirant
NyteHawk r7000
I recently reset my router, now i am able to connect using the app but only locally. How can I update so that i can connect from anywhere as i was able to before
May 23, 2022Guru - Experienced User
Enable Anywhere Access under Settings on the NH app.
miguelr0man
It is setup which is why I don't understand why it's not working
- michaelkenwardMay 25, 2022Guru - Experienced User
miguelr0man wrote:
It is setup which is why I don't understand why it's not workingYour messages are thin on useful detail.
What happens when you try to use Remote Access?
Which app are you using? Android? iOS?
