Laxa
Aug 04, 2024Aspirant
Old ‘Netgear Support’ app not possible to delete or remove on iPad
The old Netgear Support app is impossible to remove or delete on my iPad. It looks as it is trying to update itself when trying to open it, but nothing happens afterwards. The icon remains ‘faided’. ...
- Aug 05, 2024
It’s just annoying. And so old I don’t remember what I had back then. I’m now on my fifth or sixth iPad, and it has just been transferred from iPad to iPad, but it is in the last year or two it has been a ‘phantom app’ I think.
Well, not really a Netgear issue, I just asked here if someone had experienced the same problem.
Thanks for your time and answers, I will continue and try in Apple forums.
michaelkenward
Aug 05, 2024Guru - Experienced User
Which app is that?
Seems more like an iPad thing than anything that Netgear can fix. But one solution for these things can be to install the app again and then remove it.
Just another user with time on their hands.
