Laxa's avatar
Laxa
Old ‘Netgear Support’ app not possible to delete or remove on iPad
The old Netgear Support app is impossible to remove or delete on my iPad. It looks as it is trying to update itself when trying to open it, but nothing happens afterwards. The icon remains ‘faided’. ...
  • Laxa's avatar
    Laxa
    Aug 05, 2024
    It’s just annoying. And so old I don’t remember what I had back then. I’m now on my fifth or sixth iPad, and it has just been transferred from iPad to iPad, but it is in the last year or two it has been a ‘phantom app’ I think.
    Well, not really a Netgear issue, I just asked here if someone had experienced the same problem.
    Thanks for your time and answers, I will continue and try in Apple forums.
