Thomas-Miller
Sep 16, 2020Aspirant
Only shows 16 devices connected so i cant disable ones not showing.
The app shows 16 devices connected, none of which are my sons PS4 which is actively online as I type this. Of course with school starting I want to be able to disable any late night gaming but I can't...
Sep 16, 2020Guru - Experienced User
1. how is the ps4 connected to the router?
2. what modem are you using?
3. is it listed under access control?
Thomas-Miller
Cable internet (Spectrum) > Arris Surfboard SB6190 > R7000P.
PS4 while it is wifi it is primarily wired as plugged into the back of the R7000P in one of the Ethernet ports.
I apologize but I don't see where 'Access Control' is. I am using the Netgear Nighthawk app on Android.
- plemansSep 16, 2020Guru - Experienced User
try logging in through the browser and accessing it that way
