mboire
Sep 20, 2015Tutor
Other devices don't show up on the Netgear Genie "Client" App .
I have 4 Wireless IP Cameras (3 X Foscam, 1 Dlink) + several computers, NAS, printer, etc..
For some reason, 2 of the 4 ipcameras dont show up on the Attached Devices Pane nor the printer.
BUT: a...
mboire
Sep 26, 2015Tutor
All my devices uses DHCHP. I did however set use the Address Reseravation menu to prevent them to switch IP under;
Advanced --> Setup --> Lan Setup -- Use Router as DHCP Server --> Address Reservation
Then again, All my devices are setunder Address Reservation and only the printer and 2 IP Cameras are missing.
All 4 IP cameras are setup the same way.
TheEther
Sep 27, 2015Guru
Can you check the logs on the router and confirm that the 2 IP Cameras and printer are being assigned IP addresses by the router?
Does the problem persist across a reboot of the router?
- mboireSep 27, 2015Tutor
All 4 IP cameras incl. the 2 missing and the printer are listed in the log ...[DHCP IP: (192.168.1.8)] to MAC address...
And yes, the problem still persists after router was rebooted (Firmware 1.0.2.44).
In addition, support made me upgrade the Firmware to the latest release (1.0.2.46), therefore it was rebooted again... the problem was not resolved.
- TheEtherSep 27, 2015Guru
Strange. Well, I only have a couple more ideas left.
- Do you have Access Control enabled? If so, make sure that the missing devices are not blocked. Better yet, disable Access Control altogether.
- Try removing the Address Reservations, temporarily, for the missing devices. Restart the devices.
- mboireSep 28, 2015Tutor
I disabled Access Control, removed the Printer IP from the Address Reservations, shutdown and restarted the printer... no change, its still missing from "Attached Devices".
