LHL711
Oct 15, 2015Aspirant
Parental bypass controls - R7000
I have enabled my parental controls, downloaded the Genie app and change settings to so my devices will bypass the controls. Even with my devices using the bypass, I am still blocked. Let me give a...
DexterJB
Oct 16, 2015NETGEAR Moderator
Hi LHL711,
Please make sure that the DNS settings of the devices are set to be obtained automatically from the router. Also, make sure that when LPC (Live Parental Controls) is enabled that the router's DNS are set to the OpenDNS servers of 208.67.222.222 and 208.67.220.220. If not, you can have them manually set.
Dexter
Community Team
LHL711
Oct 21, 2015Aspirant
My DNS setting were on automatic but I manually changed them to the ones you suggested. After I did that, my Mac was able to bypass but my phone and iPad was not. It seemed that my iPad kept logging me out because it made me log in to the genie and do the bypass login every time.
Also, when I would check my network. Map and click on the device to check status, it would show the bypass login was engaged. Again, that was. It the case for the devices in question.
I ended up disabling the parental controls until I have more time to play with it. Any more ideas, thoughts, or comments to help further with this would be greatly appreciated.
