solomani
Feb 19, 2017Aspirant
Parental Control - Curfew by device?
Hi all, Is it possible to setup a per device schedule? For example, I want device-X to have no internet access after a certain a time each day. As best I can tell I can only do this across the ...
- Feb 21, 2017
solomani wrote:
Thanks. But the pdf only goes to page 127 :) Looking at the scheduling section it doesn't really help. Is there another section I should be checking?
Somehow my cut/paste went bad, and I linked you to the R6300 manual by mistake. I've corrected that link - the page numbers were correct in my earlier post.
FWIW, you can find the manuals, data sheets, and firmware by entering "Netgear D6400 support" into google, and clicking on the Netgear link - normally at the top of the search page.
solomani
Feb 20, 2017Aspirant
Hiya,
DS6400 with V1.0.0.56_1.0.56.
Feb 20, 2017Guru - Experienced User
solomani wrote:
Hiya,
I am guessing you meant the D6400. The instructions on page 130-131 of the manual show how to do it: http://www.downloads.netgear.com/files/GDC/D6400/D6400_UM_EN.pdf?cid=wmt_netgear_organic
You'd use "all" for the service. Also set up the device so it has a reserved IP address (otherwise the rule won't kick in). If this is a device with both ethernet and wifi you will need two rules (and two reservations) - one for ethernet and one for the wifi connection.
- solomaniFeb 20, 2017Aspirant
- aalexandrebetaFeb 20, 2017Master
Curfew by device that is called a locker with a key!
Just liking, I am Switzerland :)!
- StephenBFeb 21, 2017Guru - Experienced User
