solomani
Feb 19, 2017Aspirant
Parental Control - Curfew by device?
Hi all, Is it possible to setup a per device schedule? For example, I want device-X to have no internet access after a certain a time each day. As best I can tell I can only do this across the ...
- Feb 21, 2017
solomani wrote:
Thanks. But the pdf only goes to page 127 :) Looking at the scheduling section it doesn't really help. Is there another section I should be checking?
Somehow my cut/paste went bad, and I linked you to the R6300 manual by mistake. I've corrected that link - the page numbers were correct in my earlier post.
FWIW, you can find the manuals, data sheets, and firmware by entering "Netgear D6400 support" into google, and clicking on the Netgear link - normally at the top of the search page.
solomani
Feb 24, 2017Aspirant
Hi StephenB this worked perfectly thanks for your help.
aalexandrebeta
Feb 24, 2017Master
