iamhives
Jan 21, 2015Initiate
Parental Control And Netgear Genie
Just got a an R7000 and am currently running stock firmware - not updated to the firmware released yesterday. I love it in every way except for the nonsensical parental controls. I'm fine with the us...
pelbro
Aug 17, 2015Tutor
I have a NetGear R7000 which I purchased almost a year ago. Like most people I really like it, what I hate is the Network Genie Bypass Account setup. It really is horrible. I have finally set aside time to set up all the parental controls and my main concern is the grandkids access "things" on the internet they shouldn't be. I have two laptops for them to use, other than that everyone else and the major users are all over 50.
Just because you set up a bypass account for a particular family member does not mean they are computer / network savy. I just need something that is VERY EASY to log on to and utilize the bypass settings. Plain and simple. This featured needs a MAJOR OVERHAUL. It is way too complicated for something that should be so simple.
Anyone have any suggestions?
- RickykdeanSep 12, 2015Aspirant
The problem I have is that my iPhone won't stay logged into the bypass account. I can only occasionally use my wireless to access sites that are restricted for general use. In those cases I have to turn off the wireless access on my phone. This used to work with an older version.
- DexterJBSep 14, 2015NETGEAR Moderator
Hi Rickykdean,
I will need the following information for me to provide you with a recommendation:
1. May I know what is the model number of your NETGEAR device?
2. May I know what is the firmware version?
3. What is the iOS version of your iPhone?
4. What is the version of NETGEAR Genie app that you are using?
5. What version of the NETGEAR Genie app worked for you before?
6. How long does it stay connected?
Dexter
Community Team
- RickykdeanSep 15, 2015Aspirant
WNDR3400v31. May I know what is the model number of your NETGEAR device?
V32. May I know what is the firmware version?
8.4.1
2.4.124. What is the version of NETGEAR Genie app that you are using?
I don't remember, it's been awhile.5. What version of the NETGEAR Genie app worked for you before?
Most of the time I can't get it to work at all. But when I leave the program and come back to it I usually have to reselect the bypass account.6. How long does it stay connected?
